Using a powered sub with the T7 EC?
0 Members and 1 Guest are viewing this topic. Read 4314 times.
John B
« on: 12 Jun 2003, 06:28 pm »
What's the best way to hook up a powered sub to the Transcendence 7 EC pre-amp?
avahifi_lj
« Reply #1 on: 12 Jun 2003, 07:56 pm »
Hi:
All of the AVA styled preamps have two sets of line out jacks.  You should be able to plug your sub into the second set of line out jacks.  At the shop we connect the Biro Kensington sub to the second set of line out jacks of the T7.  It may also be possible to drive your sub from the power amp.
Thanks for you interest in AVA products!
Larry Jenkins
stealth
« Reply #2 on: 18 Jun 2003, 01:53 am »
Does that include the 200 CA?
avahifi_lj
« Reply #3 on: 18 Jun 2003, 03:30 pm »
Hi:
The Control Amp does not have a line-level out as there is no preamp section in the unit.  A sub would need to be run from the speaker outputs.
Larry
