Slimserver won't start...
0 Members and 1 Guest are viewing this topic. Read 2338 times.
mcgsxr
« on: 9 Aug 2006, 02:40 am »
Not sure what has changed, nothing intentional that is for sure, but when my PC boots, Slimserver fails to start up, it just hangs there in my tray, saying that it is starting...
Any ideas?
sunshinedawg
Re: Slimserver won't start...
« Reply #1 on: 9 Aug 2006, 03:17 am »
I just had this problem. Not sure what caused it or how I really fixed it. I was having trouble with some viruses and my system was doing some weird things. Once I got the system ok, slimserver would just hang on starting. I uninstalled and reinstalled 3 or 4 times. That didn't seem to fix it. My wife said let me look at it(I was a little skeptical about her being able to fix it). She cleaned up all my temp files. The next time I started slimserver, it started right up. There is a faq topic on the slim site dealing with exactly this, but it didn't help me. http://faq.slimdevices.com/index.php?action=artikel&cat=2&id=5&artlang=en
mcgsxr
« Reply #2 on: 10 Aug 2006, 11:51 pm »
I reinstalled slimserver, and it works again.
But I have had to upgrade to 6.3.1, and firmware 55, vs the firmware 15 I was using before - this matters to me, since version 15 inverts phase, as does my Bolder modded SB3, so short term I have resorted to swapping the + and - leads of my speaker cables, but I will have to sort out that version 15 thing later on.
Thanks for the advice,
mgalusha
« Reply #3 on: 11 Aug 2006, 12:07 am »
Mark,
You can use my firmware selector to easily put v15 firmware in place.
http://www.audiocircle.com/index.php?topic=26453.0
Mike
mcgsxr
« Reply #4 on: 11 Aug 2006, 02:16 pm »
Thanks Mike, I will try to sort out IF the 6.3.1 version of Slimserver will allow the use of V15 firmware - when I rebooted the SB3, it forced an update of the firmware.
I had been using a previous version of Slimserver, that did allow the use of V15, and would seek to return to that.
Does anyone know where I can download an older version?
mgalusha
« Reply #5 on: 11 Aug 2006, 04:33 pm »
Mark,
There is a link to the v15 firmware in the post.
http://mikegalusha.home.comcast.net/squeezebox2/squeezebox2_15.bin
mike
mcgsxr
« Reply #6 on: 11 Aug 2006, 04:52 pm »
Thanks Mike, I am likely not explaining myself well.
V15 I have, and where it should be in the directory.
The current version of the Slimserver s/w that sits on my PC does not work with V15 firmware in the SB3...
mgalusha
« Reply #7 on: 11 Aug 2006, 05:24 pm »
Sorry Mark, I thought you meant the firmware file. You can grab every version ever released at: http://www.slimdevices.com/downloads/
Mike
mcgsxr
« Reply #8 on: 11 Aug 2006, 07:35 pm »
That is PERFECT, thanks Mike.
Now I can research which s/w release people liked with V15 firmware, and get back what I had!
Appreciate your taking the time my friend,
mcgsxr
« Reply #9 on: 12 Aug 2006, 03:24 pm »
Ahh, I see what has happened here.
I had to reinstall Slimserver, for whatever reason.  I installed the latest version, which realized an older version of the firmware for the SB was in place, and forced an update of that.
Subsequent use of the s/w that mgalusha distributed, has me running V15 firmware on my Bolder modded SB3, using the latest Slimserver s/w for my PC.
Thanks again Mike!
oris98
« Reply #10 on: 12 Aug 2006, 05:28 pm »
Hi Guys,
Which version of firmware gives the best audio sound in the current 6.31 server software ?
Version 15 ?  or later ?
Thanks.
