Source for speaker spikes that are hand-tightened from above
0 Members and 1 Guest are viewing this topic. Read 895 times.
DSK
Does anyone have any sources for those spikes that are mounted through the bottom plate of a speaker stand and hand-tightened/levelled from above?
 I recall seeing a floorstander speaker ages ago that had outrigger feet fitted with such spikes. The hand-tightening disc on top was approx 1-1.5" diameter. I can't remember where I saw it.
The closest thing I can currently find is pictured on the Talon Hawk stands.
http://www.talonspeakers.com/products/referenceframe.html
EDIT: Just re-found where I saw them:
http://www.whatmough.com.au/ Select 'Signature' Series and scroll half way down for close-up.
I'll see whether Whatmough are prepared to divulge their source. Meanwhile, any other sources for similar spikes would be appreciated.
« Last Edit: 8 Aug 2006, 07:41 am by DSK »
jules
Darren,
sorry I can't help you with the spikes but looking at the Whatmough site, it seems they have increased their range significantly since I last checked it out [unless I didn't look closely enough last time]. There's some seriously upmarket stuff in there.
jules
jackthecat
Hi DSK
Have a look at
http://www.soundocity.com/
I am in NZ and have a need for these as well and spotted them after months of browsing the interweb.
also try
http://www.oregondv.com/index.html
cheers
tony
DSK
Thanks Tony, looks like some good options!
Danny Richie
    • http://www.gr-research.com
I have some new spikes. On sale too.  :D
http://www.gr-research.com/accessories/spikes.htm
