pwr switch pop sound
0 Members and 1 Guest are viewing this topic. Read 1274 times.
G Georgopoulos
« on: 6 Aug 2006, 11:54 pm »
Hi all when i switch on the amp there is a loud pop, any ideas on how to cure this problem?
john1970
Re: pwr switch pop sound
« Reply #1 on: 6 Aug 2006, 11:59 pm »
I believe to solve this problem you would need to install a circuit that would disconnect the speaker outputs until the amp turns on (i.e., capacitors fully charge).  Some amps, such as NAD, disconnect the speakers automatically during power on and power off to prevent the popping sounds during power up and the winning sounds during powering off.
Unfortunately, I don't have any other suggestions. Hopefully someone else on the form has much better ideas.
John
G Georgopoulos
« Reply #2 on: 7 Aug 2006, 12:04 am »
Thanks John for your great contribution(appreciated)  8) but i would like something simpler maybe
someone here knows about it,please do share your idea thanks :thumb:
markC
« Reply #3 on: 7 Aug 2006, 12:09 am »
You are of course turning on the amp last after the source and pre, etc.?
bgewaudio
« Reply #4 on: 8 Aug 2006, 05:26 pm »
There is something simpler, turn your power amp off and on, only when you pre/pro is on, if you turn the pre/pro off first, you will get the pop when you turn you power amp off!
nathanm
« Reply #5 on: 8 Aug 2006, 09:29 pm »
Connect a second identical amp and set of speakers wired in reverse polarity facing your existing speakers.  Turn both amplifiers on at the same time and the two pops will cancel each other out. Or at least be very reduced in volume.  In order to speed up this process build a set of remote controlled hydraulic platforms that raise and lower the second set of speakers from beneath the floor.  This way they may be lowered out of the way once the amps are turned on.
G Georgopoulos
« Reply #6 on: 8 Aug 2006, 10:23 pm »
Hi I think so far John's solution is the simpler, a relay and a few parts can eliminate the problem
completely
thanks to all the guys who contributed
cheers
