Mineral wool questions (Bpape?)
0 Members and 1 Guest are viewing this topic. Read 1705 times.
mfsoa
« on: 5 Aug 2006, 02:01 pm »
For the 4" panels, how easy is it to cut? If I want to rip it lengthwise will I be cursing myself?
bpape
    • Sensible Sound Solutions
Re: Mineral wool questions (Bpape?)
« Reply #1 on: 6 Aug 2006, 09:06 pm »
If you're talking about cutting a 2x4 into a pair of 1x4's that are still 4" thick, it's not too bad if you make a jig and use an electric carving knife.  It won't cut as cleanly as 703 or 705 but it's very doable.
If you're talking about slitting it to be 2'x4'x2" thick, don't even think about it - it will be a mess and you'll be doing some serious cursing.  Buy 2" thick to start with.
Bryan
Glenn K
« Reply #2 on: 10 Aug 2006, 02:04 am »
Just to clarify, if talking about raw material you can cut it. If you are talking about cutting a GIK 244 (4 inches) NO WAY. We would need to custom make that for you.
Glenn
