New floor spikes now available
0 Members and 1 Guest are viewing this topic. Read 2769 times.
Danny Richie
RAW
Re: New floor spikes now available
« Reply #1 on: 1 Aug 2006, 05:21 pm »
Cool Danny.
As a cabinet builder you have to like these.
Say good by to them ugly T-Nuts.
These are very easy to install.
Drill a hole and tap them in.
That is it.
And the price well done Danny
HChi
« Reply #2 on: 1 Aug 2006, 06:01 pm »
Danny, are there other thread size available?  If so, I would like to over a few sets.  Thanks.
brj
« Reply #3 on: 1 Aug 2006, 06:51 pm »
Looks good, Danny!
Are those 3/8" posts @ 16 threads/inch?
Danny Richie
« Reply #4 on: 1 Aug 2006, 07:16 pm »
I don't have them in various thread sizes, and I think these are 8mm.
mpauly
« Reply #5 on: 1 Aug 2006, 09:08 pm »
Definitely ordering a few sets.
Your page lists the chrome set as an August Special for $6.95.  I think that might be a typo, they ring up as $10.95 (which seems correct given the normal individual/set pricing).
Other than cosmetic any difference between the chrome and the brass?
Danny Richie
« Reply #6 on: 1 Aug 2006, 09:38 pm »
You are correct. Chrome ones are on sale for $10.95 a set.
That's what happens when you cut and paste as you make a new page.
The chrome is identical in size to the Brass they have just been chromed.
HChi
« Reply #7 on: 2 Aug 2006, 04:27 am »
I know I can use two sets of M8.  Could you check that for me? Thanks.
Papajin
« Reply #8 on: 2 Aug 2006, 05:51 am »
Those look hauntingly similar to spikes that I got with an av123 subwoofer! :)
Danny Richie
« Reply #9 on: 2 Aug 2006, 12:58 pm »
They could be from the same supplier.  :D
