0 Members and 1 Guest are viewing this topic. Read 13158 times.
George... what speakers are you using in the HT now that the HT3s are used elsewhere?Nevermind... when this posted I got my answer!
Well, thats good. I am from Catskill, NY, but moved out here about 8 years ago. Bad move for the hobby as this area is not into the audio scene like back east. Are the Salks hard to "tame" in the new wood and gypsum room?I like the laid back sound of the Sonatas, very pleasing, can listen for a long time.
Nice! I think the room actually looks better with the corner traps up.
Zoo,> What's the msrp on these things? They look pretty sturdy. <I'm now (frantically!) updating our web site to list the Tri-Corner as well as two other new products. I expect to have this done today or tomorrow, so you'll be able to read more very soon about all the new models.The price is $249.99, which is a little higher than our other panels. But this is a very expensive piece for us to manufacture due to the way it's built. The rear of the trap telescopes into the corner such that it looks only one inch thick even though it's really four inches deep. We also have a new MondoTrap model built the same way, with beveled edges to better fit in a corner and look like it's only one inch thick.It was important for us to make the Tri-Corner trap as large and thick as practical, because anything much smaller or thinner just won't absorb enough bass to be useful. So there are four separate layers of absorbing material inside, each a different custom size cut by hand into the shape of a triangle. But hopefully the extra effort will be worth it, and other people will think it looks as nice as we do. --Ethan
GeorgeHave you had a chance to redo your Tact curve and determine the effect of the new traps on room response?Bob
