Overheating 2B?
0 Members and 1 Guest are viewing this topic. Read 2929 times.
robertG
    • Atelier Speakers
Overheating 2B?
« on: 27 Jul 2006, 07:36 pm »
My trustworthy 2BLP is strangely overheating... Any idea of what may cause this?
I did not observe this before. The case is very hot and I couldn't leave my finger on it for over 3 seconds...
The amp doesn't pump over .5 or 1 watt (high efficiency speakers - small lab). Sound is fine, but heat is problematic...
  • The Demo is Everything!
    • http://www.bryston.com
Re: Overheating 2B?
« Reply #1 on: 27 Jul 2006, 08:34 pm »
Hi Robert,
Anything in the system change recently?
Are both sides the same temp?
james
robertG
    • Atelier Speakers
Re: Overheating 2B?
« Reply #2 on: 27 Jul 2006, 08:51 pm »
Hi James
As far as I can tell, both sides are pretty hot.
The system changes everyday, I use my Bryston in my developement work for Atelier Speakers and Gemme Audio.
As said all speakers are efficient and have no crossover in the circuit. All connections seems to be OK, indicator lamps are green...
robertG
    • Atelier Speakers
Re: Overheating 2B?
« Reply #3 on: 27 Jul 2006, 08:54 pm »
I tried a different amp I had around (an old Pionner ss) with no overheating problem, so iI'm a bit puzzled...
Robert
robertG
    • Atelier Speakers
Re: Overheating 2B?
« Reply #4 on: 27 Jul 2006, 08:59 pm »
Would it help diagnostic if I left the amp on with nothing connected (no input, no speaker cables)?
Re: Overheating 2B?
« Reply #5 on: 28 Jul 2006, 10:52 am »
Yes it would help with nothing connected - if it is the bias.
james
robertG
    • Atelier Speakers
Re: Overheating 2B?
« Reply #6 on: 28 Jul 2006, 12:00 pm »
Tried it yesterday with no music (preamp off): still overheating
Will try today with no music (preamp off) and no speaker cables attached and report back.
Robert
robertG
    • Atelier Speakers
Still overheating
« Reply #7 on: 28 Jul 2006, 01:02 pm »
Preamp off
No speakers connected - no wires
Still getting hot, same for the two sides.
Any idea?
Re: Overheating 2B?
« Reply #8 on: 28 Jul 2006, 02:35 pm »
Hi Robert,
Sounds like the bias circuit needs to be adjusted.
Contact service at Bryston.
Are you in US or Canada?
james
robertG
    • Atelier Speakers
Re: Overheating 2B?
« Reply #9 on: 28 Jul 2006, 03:05 pm »
I'm in Canada.
I contacted service yesterday by Email.
Mag
Re: Overheating 2B?
« Reply #10 on: 28 Jul 2006, 03:35 pm »
   I have a 2B-Lp and it gets hot to the touch as well. I think this is normal operating temp. for this unit. My 3B-SST in comparison is just warm to the touch.
robertG
    • Atelier Speakers
Re: Overheating 2B?
« Reply #11 on: 28 Jul 2006, 03:45 pm »
The amp would get hot overtime, but these days it's really really hot with no reason. I could probably cook an egg on the top cover...
.... but I'm not sure I'd like to eat it  :lol:
