Correct installation of Eighth Nerve Response Corners?
0 Members and 1 Guest are viewing this topic. Read 818 times.
IronLion
I installed my Response Corners last night and they made a big improvement, but one thing from the instructions has me wondering if I installed them correctly.  It says to straddle them over the corners so that sound pressure builds up behind them; the way I installed them, they cover the walls completely, that is, there is no gap between any part of the triangle and the wall.  I am guessing that this is the proper installation method, but I just wanted to double check with other people.  Its not necesssary for me to leave a small gap between the wall and the Response Corner in order for sound pressure to build up behind it is it?
PhilNYC
Re: Correct installation of Eighth Nerve Response Corners?
« Reply #1 on: 25 Jul 2006, 08:04 pm »
The Response Corner should be pulled tight across the corner, with the only contact points to the wall being the thumbtacks and the edges of the Corner:
