adapter for spade to spring clip speaker terminal
0 Members and 1 Guest are viewing this topic. Read 3522 times.
marvda1
  • freelance reviewer: The Sound Advocate
« on: 22 Jul 2006, 09:31 pm »
is there an adapter you can purchase in order to use spade connectors with the old push spring speaker terminals?
Dave G
Re: adapter for spade to spring clip speaker terminal
« Reply #1 on: 22 Jul 2006, 09:46 pm »
I think Wayne at Bolder Cable makes what you're looking for.  Go to his website, click on "System Accessories and Adaptors" on the left, and scroll down to the "Binding Post Adaptors for Spring Clip Amplifiers."
Dave
marvda1
« Reply #2 on: 22 Jul 2006, 09:56 pm »
 thanks, looks like you might be able to get the parts at radio shack and make your own.
« Last Edit: 22 Jul 2006, 10:38 pm by marvda1 »
