Bryston BP25 Remote Codes
0 Members and 1 Guest are viewing this topic. Read 2369 times.
mv038856
« on: 22 Jul 2006, 02:23 pm »
Hi there!
I just acquired a used BP25MC pre and want to integrate it into my Crestron Home automation. Does anyone out there have a Crestron IR-file for the unit?
A .ccf file for a Philips Pronto would also be highly appreciated.
I couldn't find anything on the Bryston web site. As the BP25 doesn't react on my old SP-1 remote, the codes seem to be different on the two models.
Markus
mv038856
Re: Bryston BP25 Remote Codes
« Reply #1 on: 16 Aug 2006, 07:01 pm »
Hi there!
Markus
James,
could you please provide some information on the IR signals of the BP25!?
Markus
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 17 Aug 2006, 02:07 pm »
Hi there!
Markus
James,
Markus
Hi Markus - email me a bryston and I will send you the .ccf file.
james
