0 Members and 1 Guest are viewing this topic. Read 6787 times.
I hooked the CD player to one input of onix SP-3, and SB-3 was connected to the only other input. I played the same song through SlimServer, and CD player.Now, for whatever reason, i was always under the impression that there should not be any difference between the two (as flac is supposed to be loseless format).But even to my untrained ears, i could make out that the song through SB-3 didn't quite have the same amount of detail. It surely sounded a lot better than MP3,but i was expecting flac to be identical to uncompressed audio.
Rip a CD to WAV and convert it to FLAC like you've been doing but this time dont delete the WAV files (or turn off the auto delete option).Listen to both WAV and FLAC and let us know which sounds better. If you hear a difference between the 2 then something is very wrong. If you dont hear a difference then we are headed in the right direction.
Do you come out of your SB3 via the analog or digital outputs? Same question about your CDP.Did you try swapping the inputs on the SP-3 around? Did you use the same cable for both or try switching cables?We want to remove every equation possible and find the source of the problem.
* * * Btw, on a separate topic ... i notice that EAC doesn't seem to populate CD information from free-db correctly. But when i go to free-db website, i can pull out information about the disc just fine. Anybody face this problem? For now, I'm manually entering the information, but i don't want to be doing this for a majority of my CDs. Any work arounds?Thanks!
http://www.mediamonkey.com/
I use Mediamonkey Code: [Select]http://www.mediamonkey.com/ to tag my FLAC files, and to associate them with CD covers, after I have ripped them with EAC. Mediamonkey has an easy system to tag the files from Amazaon's listings. These tags aren't 100% perfect, but it is also very easy to manually correct the tags with Mediamonkey.PS-how do you properly link to webpages under this new board setup? I can't figure it out.
Cacophonix:I've had good luck following the guidelines at http://users.pandora.be/satcp/ You can also get some good tips at the Exact Audio Copy site www.exactaudiocopy.de in the Forums section.
Ive slowly moved away from EAC in favor of the new plextools pro (I only use plaxtor premium drives) because its autosets the correct drives settings and values. Then again it costs a bit of money and EAC is free.
Couple of things check.REPLAY GAIN Make sure its disabled, this can indeed kill your sound quality.Can your print off your EAC settings or export your profile for us to take a look at?Make sure EAC is configured correctly for your drive (i.e. correct values for read offset are set)Ive slowly moved away from EAC in favor of the new plextools pro (I only use plaxtor premium drives) because its autosets the correct drives settings and values. Then again it costs a bit of money and EAC is free.
Quote from: Tirade on 29 Jul 2006, 07:59 pmCouple of things check.REPLAY GAIN Make sure its disabled, this can indeed kill your sound quality.Can your print off your EAC settings or export your profile for us to take a look at?Make sure EAC is configured correctly for your drive (i.e. correct values for read offset are set)Ive slowly moved away from EAC in favor of the new plextools pro (I only use plaxtor premium drives) because its autosets the correct drives settings and values. Then again it costs a bit of money and EAC is free.Where do i check to see if this "replay gain" is disabled? Is this the same as normalization? I have this disabled in the EAC options.How do i export my profile for you all to look at? I'm a complete newbie when it comes to playing around with CD ripping options ... so i just blindly followed whatever was in the hydrogen audio forum.
