Bugle Pro @ 50dB w/ Lundhal SUT set at 20dB
0 Members and 1 Guest are viewing this topic. Read 1487 times.
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
« on: 20 Jul 2006, 05:06 pm »
Jim or anyone,
My Bugle is at 50dB gain. Are there any issues using a SUT w/ 20dB gain going into the Bugle? Will I overload the Bugle? :?:
hagtech
Re: Bugle Pro @ 50dB w/ Lundhal SUT set at 20dB
« Reply #1 on: 20 Jul 2006, 05:27 pm »
Depends on the cartridge used.  You'll have to try it out.  Maybe one of the 0.5mV to 0.8mV crowd could push it a little too far.  Also depends on supply voltage on the BUGLE.
jh
PatOMalley
« Reply #2 on: 20 Jul 2006, 07:26 pm »
The cartridge is the cultish Denon DL-103 which comes in at .3mV or DL-103R which is .25mV.
hagtech
« Reply #3 on: 21 Jul 2006, 12:38 am »
You'll probably be ok.  With +/-15V supplies easy.
jh
