LS6/9s vs. Open Baffle
0 Members and 1 Guest are viewing this topic. Read 2651 times.
Brucemck
« on: 19 Jul 2006, 03:38 pm »
How would you characterize the differences, and/or make the tradeoff, between the new open baffles and the new line arrays?
In either case I'd be running three speakers across the front ... if did line arrays I'd put one on its side for the center, which would work fine for the two center chairs as they'd be within the length of the array.
I listen to music 70% of the time and watch movies 30% of the time.  Former is mostly "vocals" and "light rock" (Wille, Bonnie Rait, Blue Rodeo, Amie Mann, etc) at loud but not obscene levels .... occasionally though I like to blast old war horses (Big Big Love by Fleetwood Mac, or, the beach scene in Saving Private Ryan) ... almost never obscenely loud (ear hurting) hard rock or big orchestras.
I use (or have available) dual 15" subs at very low end and have terrific PEQ via Meridian processor.  Room's fairly heavily treated, with bass traps, diffusion, etc., and is moderatelly large at 18'L by 14'W by 12'H
Speakers I've loved in the past had two great qualities: "wham bam" ability to really convey the "pluck" of instruments and dynamics of real sounds (old Krell Lat1s and big old Dunlavy's), and, great 3D soundstaging (my old Genesis 350SE ribbons).  If I could get both of those qualities in one place, that'd be magic.
Danny Richie
Re: LS6/9s vs. Open Baffle
« Reply #1 on: 19 Jul 2006, 11:37 pm »
You'll have to wait unitl I have the new line arrays completed for me to answer that one.
I'll have you covered.
arthurs
« Reply #2 on: 20 Jul 2006, 01:42 am »
Danny - will there be porting on the 6/9's?  we may have talked about this but I can't recall....
Danny Richie
« Reply #3 on: 20 Jul 2006, 01:21 pm »
Yes, they use a lot of ports on the rear. The LS-6 has eight 2" flared ports. The LS-9 has twelve 2" flared ports.
arthurs
« Reply #4 on: 20 Jul 2006, 02:17 pm »
Thx, really looking forward to hearing the 9's.... :thumb:
