STEP-UP Product Recall
0 Members and 1 Guest are viewing this topic. Read 1722 times.
hagtech
« on: 15 Jul 2006, 08:29 pm »
Ok, so it's not really a "recall" as there is nothing wrong with your TRUMPET STEP-UP.  What happened is that I discovered an improvement to it.  I was working with a customer on a hum problem (happens all the time).  Each system is different, installation issues such as racks, cabling, placement, other machines, tubes, everything can make a difference.  First off, we solved the NOS tube mismatches, as he also has a VACUTRACE.  That solved half of it.  But here was still some hum when the STEP-UP was plugged in.  Ok, some environments are more harsh than others.
So I played with my new GOLD STEP-UP here in the shop to try and recreate the system.  Was able to get find ways to increase hum to what I would term unacceptable.  Anyway, even though we had found a working solution, I had an hunch.  So I did an experiment.
You see, there is a small, residual ground loop made up of the coax shields that connect to the inputs of the TRUMPET.  This makes for a one-turn transformer secondary and it can pick up stray magnetic fields.  I found a way to break this ground loop inside the STEP-UP by re-wiring and adding a new ground lead.  Well shoot, it worked really well.  It immediately turned a bad environment into a quiet one.
So there it is.  The fix is not easy or straight forward, and involves new parts and a new cable.  Therefore, the upgrade can only be done at the factory, but it is plug and play.  Anyone who owns a STEP-UP can send it in for a free upgrade.  All of them are still under warranty - even if you are not the original owner.
jh :oops:
andrew
Re: STEP-UP Product Recall
« Reply #1 on: 22 Jul 2006, 08:22 pm »
Hi Jim,
  Would you be willing to post a diagram of the fix? I beleive you use TX103 step up, which I do. If you recall I have had a hum problem with these stepups and the Cornet that I have never been able to completely eliminate.
   thanks,
« Last Edit: 22 Jul 2006, 08:40 pm by andrew »
hagtech
« Reply #2 on: 22 Jul 2006, 10:44 pm »
I just float the secondaries now.  Before the shields were grounded to the stepup chassis.
jh
