0 Members and 1 Guest are viewing this topic. Read 4594 times.
Thanks for the suggestions, guys. The speakers are much less boomy with some fibreglass removed. I think further breakin has had an effect as well. I only have maybe 100 hours on them. I have also toed in the speakers dramatically, crossing in front of the listening chair.Re: the amp - Sedona Sky - yes this has occurred to me, and I'd definitely like to try a beefier amp. The Alephs are known for somewhat "loose" bass. I love the Pass sound though. Maybe an X150? Any other recommendations? No digital amps please though! ...
By on axis, you mean toed in so that the listener is exactly at the point of the triangle?
You can adjust the 626 bass by removing damping material from the cabinet. To get inside unscrew the woofer. Try taking a small handfull of fiberglass away, one speaker at a time. Have fun, it works.
