Jolida JD3000 mono blocs- give away price
0 Members and 1 Guest are viewing this topic. Read 1641 times.
Bill Baker
    • Musica Bella Audio
« on: 14 Jul 2006, 01:10 am »
These amps are like new condition but I simply have not had the chance to or need to use them. They have some upgrades as mentioned below. I originally had a problem with one of them blowing the fuse when powering up. Could simply be a bad tube but I don't have any spare 211's around. Honestly less than 20 hours on them.
 Take them for only $1500 for the pair + shipping!!!
 I have all the original packaging.
 Upgrades performed:
SoniCap Gen I coupling caps x6
Dale/Vishay 1% metal film resistors throughout x26 pieces
Riken Ohm Grid stopper and screen grid resistors x8 pieces
WBT Nextgen RCA input jacks
24 awg solid silver signal wiring
Solid Cherry face plates (original mirror finish steel plates also provided)
pacifico
Re: Jolida JD3000 mono blocs- give away price
« Reply #1 on: 14 Jul 2006, 02:39 pm »
have you considered swapping the 211s to see if the tubes are the problem?
Bill Baker
« Reply #2 on: 14 Jul 2006, 03:26 pm »
 Yes I did but never got around to hooking the amps back up. With these amps, you cannot test bench them with a simple dummy load or run a thin gauge speaker cable to them. If you do, you will not be able to get the bias anywhere near the recommended setting.
 If they don't sell, I will get back to them in time. Right now, I simply have far to much on my plate.
Bill Baker
« Reply #3 on: 14 Jul 2006, 04:36 pm »
SOLD
