Finally decided on the car system
0 Members and 1 Guest are viewing this topic. Read 2740 times.
Johng316
« on: 6 Jun 2003, 08:51 pm »
Well, I finally decided which way to go.  My first system will be relatively cheap, but I believe it's going to be very good for what it costs.
Head Unit:  Eclipse.  Not sure of model yet.
Front stage speakers:  CDT HD-62ef, the new "euro frame" design with 1" silk dome tweet; component set.  These are reputed to be very detailed and smooth-sounding (not brite like the majority of competition speakers on the market right now).  These are on the way now.
Used PPI amp from Brad (Thanks, Brad!) for the front stage speakers.  On the way!
For the future:
Subwoofer:  Single 10 or 12 from IDQ in a small box (<1 cu ft).
Subwoofer Amp:  Not sure what to get here yet.
Upgrade Rear Fill speakers:  Will probably go with CDT CL-6X coaxials.  They are relatively cheap and will be good for "rear fill" duties.  Will run these off the head unit.
I'm so excited to be finally getting some decent stuff for the car!  My wife is upset because I appear to be getting into yet another expensive hobby...    :nono:
 :P
Who else is building a car system?  What are your plans and goals for the system?
John G
HarleyMYK
« Reply #1 on: 6 Jun 2003, 09:35 pm »
I have been thinking about something like this for my wife's Honda.
http://www.boozhoundlabs.com/subaru-spkrz/
Johng316
« Reply #2 on: 30 Jun 2003, 07:21 pm »
Well, I finally got everything installed!
The CDT speakers I ordered were, as predicted, too deep for the doors in my car, so I had to build some spacers out of 1/2" MDF using a jigsaw.  This was pretty easy.
I liberally coated the exterior and interior door skins and door panel with RAAMmat 60, a dampening material, and installed the 6.5" woofers in the factory door location.  I put the tweeters in the factory A-Pillar locations, wiring the driver-side tweeter out-of-phase to raise the soundstage to eye level (this idea came from my installer, AudioCreations, who put in the amp and Head Unit).
For head-unit, I bought an Eclipse 8443, which comes with 8V pre-outs (very nice), 24 bit DAC, time alignment features, and built-in parametric EQ.  Other than that, it's pretty basic for features.  Extremely nice-sounding unit, however.  :-)
Lastly, I discovered that the used amp I picked out had a 90 hz fixed crossover point (can go high-pass or low pass, but it can't play full range).  Given this limitation, I'm saving this amp as a subwoofer amp.  I'll bridge it and run low-pass for a sub.  I have a 12" driver left over from my HT upgrade (it's one of the original SVS 20-39 drivers), and that should be nice in the car, don't you think?).  :-)
Anyway, since the PPI didn't work out, I bought an Eclipse 50x4 amp which is now bridged into 140w x 2 to drive my front-stage components.
Results:  AMAZING.  The 1" silk tweeters were surprisingly brite for the first two days but have progressively mellowed with break-in.  All I can say is I'm extremely impressed with the CDT components, and I am generally happy with the Eclipse deck as well, though I am waiting until the speakers completely break in before messing about with the parametric EQ and time alignment features.  If anyone is looking for a good Sound Quality install, and you are looking for a smooth, integrated, non-fatiguing, yet detailed sound, I would highly recommend the CDT HD components.
John G
Brad
« Reply #3 on: 30 Jun 2003, 07:36 pm »
Geez, John, sorry about the PPI.....
I didn't realize it had the x-over as mandatory.  :oops:
Glad the CDT's worked out.  They are very high on my list.
Also glad to see Eclipse using a multi-bit DAC.   I didn't care for the sound of their single bit units.
Johng316
« Reply #4 on: 2 Jul 2003, 03:23 am »
No problemo, Brad.  I didn't realize either until my installer tried to put it in, and he called me.  I had to make a quick decision and decided to go for the Eclipse amp, which is a mid-range unit, but still very clean.
I'll still probably use the PPI for a bass amp, but if I don't, worst case scenario is I sell it for what I bought it for, as I seem to remember someone here gave me an extremely good price on it.   8)
Overall, I'm very happy.
John G
