Gain of BP-26
0 Members and 1 Guest are viewing this topic. Read 1648 times.
Bob Reynolds
Gain of BP-26
« on: 10 Jul 2006, 08:15 pm »
I finally decided to try the BP-26 with my 7B-SST amps. I searched this forum and the BP-26 manual, but I could not find the gain specification of the BP-26 linestage.
Does anyone have that spec on hand?
Are there any pictures of the BP-26's insides available online?
Bob
  • The Demo is Everything!
    • http://www.bryston.com
Re: Gain of BP-26
« Reply #1 on: 11 Jul 2006, 01:52 pm »
The Gain on the BP26 is 10.5dB unbalanced and 16.5dB Balanced.
james
Bob Reynolds
Re: Gain of BP-26
« Reply #2 on: 11 Jul 2006, 03:56 pm »
Thanks James. Looking forward to getting the BP-26.
I will likely buy the external DAC when it becomes available. I think I recall you saying that there would be two versions: one with its own power supply and one that would use the MPS-2 power supply. Is that correct?
I assume that each of the MPS-2 supplies are well isolated from each other so that powering a digital device from it won't impact any analog devices it's powering.
Re: Gain of BP-26
« Reply #3 on: 11 Jul 2006, 04:08 pm »
Hi Bob,
Yes the plan is to release a full function CD player and full function Outboard DAC first and then offer the units with or without internal power supplies later on.
james
