Harmon - It really doesn't matter whether you get it with a JRC5532 or an OPA2604, they're both standard DIP8 dual opamps with the same pinout, and both IMO subjectively mediocre opamps. Beyond purely technical criteria opamps really do have a subjective 'flavor'. I roughly divide them into 2 camps, the 'warm' BurrBrown sound and the 'clear as a bell' sound of AnalogDevices opamps. Among dual opamps I prefer the OPA2107, which is about as close as one can get to an OPA627 in a dual in the BB camp. In the AD camp, I prefer the AD8066, which isn't available in dip8, only smt, and is likely to go into oscillation unless the circuit is specifically designed for its very high speed. I have ordered some specific Linear Technology dual opamps which from prior experience should give that clear as a bell sound but available in DIP8 and not likely to self destruct when put into the Zhaolu.
Pugs - The version of the OPA2107 you'd want for the Zhaolu is the OPA2107AP which is the DIP8 version which you simply put in the Zhaolu's sockets after pulling whatever is in there. Sadly, Digikey, Mouser and Newark only have the SO-8 smt OPA2107AU in single quantities which would be fine if you wanted to replace the opamp in a Squeezebox. The 2107AP is only available in quantities of 50+ from these vendors. Nor does Ebay currently have any listed, though they usually do.
Awaiting the availability of OPA2107APs on Ebay or elsewhere, I'll make the following offer of 2 sets of 3 OPA2107APs for $20 delivered and Harmon and Pugs have first dibs. I just want to get the ball rolling, I'm not making any profit, and I don't want to deplete my stash. PM me if interested.
