PMC AB2
0 Members and 1 Guest are viewing this topic. Read 2585 times.
declancd7q
PMC AB2
« on: 7 Jul 2006, 07:43 am »
Has anyone compared the AB2 to other PMC designs like OB1 or IB2?
The Dynaudio 2400 mm driver looks impressive but at the cost of the midband finesse?
There seems to be a real shortage on information on the AB2.
How does it sound in an average to moderately-large room?
Jason Nugent
Re: PMC AB2
« Reply #1 on: 7 Jul 2006, 12:28 pm »
I have a pair of AB2S monitors in my HT, as well as an AB2M-C centre channel.  I'm driving the pair of monitors with my 4B SST and the centre channel with a bi-amped config from my 9B.   My room is fairly large (13.5'x20'), and acoustically treated, with quite a bit of low-end damping and my major reflection points are treated with fibreglass panels.  Accordingly, I have to turn the volume up quite high to really make the AB2's sound alive.   But, when you give them the power they want, they reward you quite well for it.   I can easily get 95dB at my listening position, about 10 feet away, which is more than enough volume for me.
As for midband finesse, I listen to quite a bit of progressive metal, a lot of female jazz, and quite a bit of small classical accompanyments with instruments like cellos and violins.  I am constantly impressed with how well the AB2s perform im this type of environment.
I'm not sure where you live, but you'd always be welcome to pop in and have a listen should you be in my neck of the woods.
Jason
A photo of the system, from one of the rows of seats in the room:
http://malhavoc.homeunix.com/ht/final/fin_screen.jpg
« Last Edit: 7 Jul 2006, 12:49 pm by Jason Nugent »
declancd7q
Re: PMC AB2
« Reply #2 on: 11 Jul 2006, 02:29 am »
I'm in Kangaroo-hopping, Koala-hugging Australia....but thanks for the f/back.
Sounds like the AB2 is really best suited to larger rooms even though it's a studio monitor.
