sub thumps with SP 1.7 and Velodyne SMS-1
0 Members and 1 Guest are viewing this topic. Read 1961 times.
ec
« on: 7 Jul 2006, 03:30 am »
Anybody here using the Velodyne SMS-1 with their SP 1.7?
Setup:
SP 1.7 sub out unbalanced feeds two Buttkicker Amplifiers
SP 1.7 sub out balanced feeds Symetrix 551E Parametric EQ which then feeds two Crown K1' s (hey cut me some slack all my other amps are SSTs  :P)
I replaced the Symetrix PEQ with a Velodyne SMS-1 and did a quickie auto calibrate.  Now when I turn on my SP 1.7 (which triggers on the Crowns via a switched power station) I get a slight thump in the subs.  I also noticed a pronounced thump in the subs when I switch from DVD to Satellite.  Similarly there is a cha-chunk on the Buttkickers SP 1.7 power on turn on and source switch.  These problems did not exist previously with the Sysmetrix 551E.  What seems stranger is that the SMS-1 (balanced connection) seems to affect the unbalanced connection on the SP 1.7
The Velodyne SMS-1 is always left on just like the Symetrix it replaced.  I will call Velodyne when I get a chance but I thought I would throw this out to the crowd in case they have the SMS-1.
ec
Re: sub thumps with SP 1.7 and Velodyne SMS-1
« Reply #1 on: 8 Jul 2006, 04:25 am »
After a few hours of trying to identify the problem, I found the root cause - strangely the problem only occurs with one specific Buttkicker amp (I run two BK amps) and the SMS-1.  I replaced the Buttkicker amp to minimize the thumping problem.
mlawson66
« Reply #2 on: 14 Jul 2006, 04:15 am »
Do you still have the thump when you change from DVD to Satellite? I've got a similar problem with my SP2. Whenever the digital signal changes format, ie PCM to 5.1, I get a thump out of all speakers. It is enough to blow fuses in my Ampzilla 2000 monoblocks. I manually mute before changing channels or sources now.
All of my amps will do XLR, but I have a 7.1 system, and the SP2 only has balanced outputs for 5.1.
thxultra
« Reply #3 on: 14 Jul 2006, 03:17 pm »
My DD sub thumps when using xlr connection but not with rca , the sms1 also does this when connected this way.
Not sure whether its just a velodyne thing or it happens with other manufacturers
Its just something that happens  :scratch:
ec
« Reply #4 on: 15 Jul 2006, 05:07 am »
Yes, I still get the thump when switching sources but it is greatly reduced from when I first posted.  I also get the thumps when the SP 1.7 is switching between modes or finding modes eg the "space" between the trailers on DVDs.
