is it worth it to build your own xovers?
0 Members and 1 Guest are viewing this topic. Read 2020 times.
beat
« on: 6 Jun 2003, 03:35 am »
hello all,
It seems like it would be pretty easy but how can you judge if the outcome is worth the effort?
randytsuch
Re: is it worth it to build your own xovers?
« Reply #1 on: 6 Jun 2003, 04:42 am »
Quote from: beat
hello all,
By listening?  :wink:
Seriously, I have kind of considered this too.  Putting a xover together would not be too hard, designing a GOOD xover is the hard part.
Depending on your speaker, and the quality of parts used, you can just take the existing xover, and swap in better parts. Should make a difference.
I have also considered just taking the xover out of the speaker, to get it away from the driver magnetics, I think this would help too.
Is it worth it?  Seems like it comes down to a personal decision.
Randy
beat
« Reply #2 on: 6 Jun 2003, 04:12 pm »
I hear ya,
If i cared to fork out 90 bucks for a crossover building program it would be a no brainer. Since I don't, I'm looking at using the prefabed ones from partsexpress. I've used the bottom of the line ones there and they work fine for surround speakers but I want this pair to kick @$$.
JohnR
« Reply #3 on: 8 Jun 2003, 07:03 pm »
Hi beat, I think it's hugely more difficult to design a (good) crossover than it is to build someone else's design. The former means a long road of education and experience. (I assume, I am only at the start of it myself...) It's a lot of fun to learn new stuff, but if you're more looking to build jiust one or two pairs of kick-ass speakers and then be done with it I'd be inclined to look at designs or kits from the more highly-regarded designers who publish/sell that kind of stuff -- Matt Dillon, Dennis Murphy, Rick Craig, Danny Richie come to mind.
HTH
beat
« Reply #4 on: 9 Jun 2003, 09:03 pm »
John,
where would I find kits or publishings from these guys?
JohnR
« Reply #5 on: 10 Jun 2003, 02:45 am »
Hm, OK, lessee...
http://www.gr-research.com/  (Kits only, forum on this site)
http://www.selahaudio.com/   (Ditto)
http://www.ellisaudio.com/     (Ditto)
http://www.murphyblaster.com/  (Designs)
http://www.dillonacoustics.com/index.htm  (Designs)
Others who sell kits include madisound, zalytron, and partsexpress. Oh and let's not forget CSS in canada: http://www.creativesound.ca/
Ah, and Adireaudio as well. I'm sure there's others I've forgotten.
If you could give an indication of what kind of speakers you want and how much $$ I could try to suggest a couple to look at to start with. In general I'd say don't get too ambitious, build something easy first.
There's a lot of speaker-building discussion on the Madisound board: http://www.madisound.com/cgi-bin/discuss.cgi
