Any good, samll bookshelves for ~ $200-$500?
0 Members and 1 Guest are viewing this topic. Read 1218 times.
pugs
« on: 27 Jun 2006, 07:26 pm »
I'm looking for small bookshelve speakers for a kitchen system for around $200 - $500.  Used is OK.  They need to have good dispersion and good bass.  Something with a Scanspeak 8545 would be nice, but might not be possible in that price range.  I have some NHT SuperOne's right now that I am going to sell.  I want something with a bigger sound.  I don't want anything that may be considered to be bright.  Any suggestions?
mfsoa
Re: Any good, samll bookshelves for ~ $200-$500?
« Reply #1 on: 27 Jun 2006, 07:35 pm »
Chuck listed some Paradigm Mini Monitors on June 22.
Not familiar w/ them but thought I'd point it out, in case.
« Reply #2 on: 27 Jun 2006, 07:54 pm »
Maybe this
Hiddenite
pugs
« Reply #3 on: 27 Jun 2006, 08:08 pm »
Maybe this
Hiddenite
That is one I've been looking at.  Rick also offered to make a custom 2-way with the SS8545.  It's out of my price range, but might be worth it.
brj
« Reply #4 on: 27 Jun 2006, 08:09 pm »
What is your definition of "small"?  New or used?  Stock or modded?  Any finish requirements or WAF factors?
Based on mostly reading alone, and without verifying prices, here are a few of the smallest speakers that I can think of off the top of my head:
AV123 X-LS
Usher 520
RAD Micros or Metals
Swan M1
Gallo Acoustics Nucleus Micro, A'Diva or Due
Good luck!
pugs
« Reply #5 on: 27 Jun 2006, 08:11 pm »
AV123 X-LS
Usher 520
Swan M1
Good luck!
Thanks,  I'll look into those
Bob Reynolds
« Reply #6 on: 28 Jun 2006, 07:29 pm »
You might consider several of the M&K speakers...B-1500 or B-1600
http://www.mksoundstore.com/store/merchant.ihtml?cid=16&step=2
kfr01
« Reply #7 on: 28 Jun 2006, 07:41 pm »
Small bookshelf kits are easy to build and finish and provide the best bang for the buck, in my opinion.  Have you considered DIY?
