Random Bugle questions/comments
0 Members and 1 Guest are viewing this topic. Read 1490 times.
lukpac
« on: 27 Jun 2006, 04:17 pm »
Some things for Jim or anyone else:
- is the Bugle PCB designed in any specific way, other than to lay out everything in a neat and orderly way? I.e., to reduce noise, crosstalk, etc?
- R16/R34 are to reduce the input impedance. If one wanted to vary/increase the impedance, could you just swap out R17/R35 instead?
- for anyone interested, I just built one from scratch (not using the stock PCB). Not the most pretty thing in the world, but seems to be good so far. FWIW, I'm still waiting on the OPA2134PA's (they are supposedly in the mail), so for now I just stuck in some TL082's from Radio Shack. Sounds pretty similar to my built-in phono stage; we'll see how much difference the OPA2134PA's make.
http://lukpac.org/gallery/20060626phono
Silver ink pens are a wonderful thing!
hagtech
    • http://www.hagtech.com
Re: Random Bugle questions/comments
« Reply #1 on: 27 Jun 2006, 07:19 pm »
Yes, it is extremely specific.  It may look orderly, but that's merely coincidental and the result of careful placement of signal routing.  In order to make the circuit tight with short traces and low capacitance nodes, you have to jamb the components together, and the only way this happens is when they line up.  Hence, the orderly appearance follows function.  Not the other way around.  At least with my boards.  There are many examples in the hi-fi world where it is all about visuals, not signals.  You can best see this in my layouts by looking at just the traces, no components.
I also choose to sacrifice crosstalk in favor of stability and sonics.  Considering you get maybe 30dB to 40dB channel separation out of a cartridge, there is no point having 80dB worth of channel separation in the phonostage.  I purposely sacrifice this parameter in order to improve other more significant ones.  The result is no loss in performance for crosstalk, just a lower number on the spec sheet.  Hence, you will see dual opamps with each side of the chip operating on a different channel.  Compare this to what most other designers do, and that's to put subsequent gain sections of one channel into a dual opamp.  The danger is that you get parasitic feedback, often positive!  That's right, the output of one pin on the chip is 100 to 1000 times greater than another pin.  What you get is unwanted feedback and HF instability.  This also happens via the supply rails of the chip.  The situation is even worse with dual triodes.
So in short, it's not about beauty, but purpose.
Yup.
Unfortunately, you'll never get the performance possible with the circuit board.
jh :)
« Last Edit: 27 Jun 2006, 07:29 pm by hagtech »
lukpac
« Reply #2 on: 27 Jun 2006, 07:21 pm »
What type of problems would I have?
