Bugle P/S heat sink question.
0 Members and 1 Guest are viewing this topic. Read 1276 times.
nimrod
« on: 25 Jun 2006, 11:01 pm »
I have a couple of questions concerning the regulators/ heat sinks for the bugle P/S. Which hole should I connect the regulators to on the sinks? If I connect them to the top hole, the legs of the reg. barely go into the holes on the board. If I use the washers under the sinks, the legs won't reach into the board. If I connect them to the middle hole, some of the body of the reg. sticks out under the notch in the sink. The heat sinks that I have, which have the correct number on the package from Digikey (HS 191) are 1.5 inches tall. They appear noticeably taller than the ones in the picture of the P/S on the front of the manual. Also, do I use some compound when I mount the reg's. to the sinks, and should I use insulators between the reg's. and the sinks?
hagtech
    • http://www.hagtech.com
Re: Bugle P/S heat sink question.
« Reply #1 on: 26 Jun 2006, 03:12 am »
Bottom hole is ok.  There's not much heat in this design.  No need for goop.  In fact, it will probably run ok without heat sinks.
jh
nimrod
« Reply #2 on: 26 Jun 2006, 03:19 am »
OK, thanks! I went ahead and elongated the top hole slightly to bring the reg's. down and just bolted 'em up w/o any goop.
