Yeah Les, another guy here posted last week that he just pulled the trigger on a DeHavilland Mercury II
That guy may be me. I bought a used Mercury 2, though it was only a few months old. It arrived minus one tube, so the seller sent me some alternate tubes he had. The unit now has Tung-Sol for the type 85 tubes. I should note that I am not a "learned" audiophile. What I mean is that I have built my system using the advice of other folks here and elsewhere. Anything I can say about this unit is merely per my ears. And, I have no room treatments either.
At first I was horrified when I powered up the pre, as it sounded very grainy. But it really needed to heat up, and the tubes had not been used in the system. Soon, though, it began to tighten up, and improve in clarity. Prior to this pre I had been using a Yamaha integrated as my pre, into Odyssey Extreme Monos. The Yamaha colored the sound alot, higher highs, lower lows. After losing that, I initially felt the sound was compressed with the mercury. But, I began to realize how much less fatiguing it was, and after awhile getting used to it, I began to like it very much. I guess I needed to break in a bit as much as the pre and tubes did for me. It has become obvious to me that my source needs to be changed out. I am still upgrading. My upgrade path was VMPS RM2 speakers, waited 4 years, bought the Odysseys, waited 10 months, now the mercury preamp. I think I may have been better off upgrading my source before the pre though. I have a Yamaha 5 disk changer, and a Panasonic DVD player. It became obvious that the Yamaha multi disc player sounds worse than the Panny, so it is doubtful I will use that much anymore. THe Panasonic sounds OK I guess, but I feel I am very limited by it. I am considering the modded Denon 2900s available on Agon, wondering about the differences between the Exemplar and the Modwright(gonna start a thread for this). Anyway, my experience so far is not terribly valuable as I feel my source is now limiting me.
Regardless, I feel that the preamp is very detailed, imaging is
FAR superior to what I had with the Yamaha in the loop. I feel I lost some of the low end that I had with the Yamaha, but again, I am not sure that it should have been there in the first place. Not to say the Mercury doesn't have low end, just not as boomy as the Yamaha was.
Well, I hope this helps.
