0 Members and 1 Guest are viewing this topic. Read 3394 times.
John,I use the super cheap yellow matress foam you can get at Target. You can cut them to any shape and size. This is the stuff I'm still using in the main woofer cabinet as a "sonic barrier". I have real stuff, but haven't the time to install this yet, as I'm still satisfied with the cheap foam. Yeas the egg Crate foam from Parts Express will work to , but I'm sure to different effect cause it's stiffer and the poars are larger.Good luck, Stan
Audiochef,Can you please provide more specifics for those of us who would like to do the tweak as well. I own a pair of RM40s and would be interested in performing the tweek. I assume you cut the foam to fit just behind each midrange panel, but I am not certain. It would be much appreciated if you could:1) Give the specifics on the foam (thickness and manufacturer)2) Provide some detailed instructions.
The amount of matress foam I'm using is lined in the enclosure is on top, backs and above and below the tweaters.
Hi Bruno,I have original RM40s, two FSTs per speaker. I don't know if photos are still in the gallery or not.The amount of wool I'm using is 1 pound per speaker, as weighed by Maddisound. I think Brian is using 1.5 lbs. per speaker from the factory.Yes the enclosures are lined with matress pads in addition to the wool.May I also add that for me I can turn up the mids even a bit further now without fear of excessive brightness. A good good thing . Stan
