Starting fresh
0 Members and 1 Guest are viewing this topic. Read 1433 times.
EDS_
Starting fresh
« on: 3 Jun 2003, 06:28 pm »
My current system is jury rigged 5.1 (three Adcom GFP-750 pre-amps, Hales Rev. 3s {3 across the front} with Triangle Zephyrs for rear action-Llano amplification and Cary CD303 and Rotel DVD-A front ends).
I want to start fresh. I'll likely re-rig the above for a two channel system.
I want to build a 5.1 audio system from scratch for SACD and DVD-A.
Right now I'm leaning McCormack. Their unreleased UDP-1 ($3K) seems like the front end for me. The MAP-1 ($2.35K) seems, and sounds, like a great analog 5.1 pre-amp.
What would you guys do-is there another 5.1 pre-amp that would be worth a listen?
What about amplification?
BTW-The New White Stripe CD "Elephant" is greatness.
Speakers?
I want the total bill to be between $9K and $12K.
I want all new gear.
Anyone familiar with the Oddyssey amps?
Belles amps?
Meadowlark Osprey speakers?
PMC speakers?
Thanks.
JoshK
Starting fresh
« Reply #1 on: 3 Jun 2003, 07:06 pm »
I totally agree on the White Stripes comment.  I have heard great things about the McCormack pieces you ask about but have not heard them so I will be silent.
Danny Richie
    • http://www.gr-research.com
Starting fresh
« Reply #2 on: 3 Jun 2003, 07:32 pm »
Hey EDS,
I highly recommend you take a 20 minute drive over to Garland to visit Dodd Audio and listen to his tube amps and tube pre-amps.
His world class efforts are actually very affordable, and you'll be blown away by what you hear.
Gary Dodd: [email protected] or call 972-276-6865
Starting fresh
« Reply #3 on: 3 Jun 2003, 07:40 pm »
I would suggest VMPS RM-2's all around (with the new FST Tweeter), and a VMPS Larger sub.
For Amps, I really like the Audio by Van Alstine stuff.  These are great amps.
