Any Issues Hooking up REL subwoofer to D200's?
0 Members and 1 Guest are viewing this topic. Read 2332 times.
tnewell
« on: 15 Jun 2006, 04:51 am »
Hi,
I was wondering if there any problems hooking up a REL Stadium III to the D 200's?
I assuming you would just hook up the positive & negative wires to one D200 and the other positive to other D200?
Tom
CIAudio
« Reply #1 on: 15 Jun 2006, 05:14 am »
There should be no problem, the amplifiers are common ground and do not have floating DC on their outputs. Just connect them as the REL manual suggests.
Robert57
« Reply #2 on: 15 Jun 2006, 02:08 pm »
I am also interested in a REL-type sub connection and was assuming I could easily do some sort of a parrallel speaker post connection. Some amps make this easy by allowing both a bare wire (or spade) connection in addition to a banana plug connetion in the ends. From the photo on the CI website, I think I see a banana plug connection,  but I don't see the spade or bare wire screw .
Dusty, could you elaborate a bit on how one would wire a parrallel sub connection on your posts. Do you offer any alternate posts which allow both bare wire (or spades) and banana plugs? I would rather not have to twist the bare wire and connect both sub and L-R speakers to one plug, just to maintain the best connections and flexibility in swapping cables.
Thanks.
Rob
CIAudio
« Reply #3 on: 15 Jun 2006, 02:23 pm »
Our posts can accept spades(or bare wires) and also have banana jacks.
