Monster cable burns!!
0 Members and 1 Guest are viewing this topic. Read 2639 times.
rahank
« on: 13 Jun 2006, 07:22 pm »
Hi new to the forum. I have Odyssey Strat with cap upgrade and Tempest Pre.  VA Mozart speakers.  Love it so far!!
My monster speaker cable is about 7 years old. Don't remember which one it is. Pretty thick.  I would say 12 gage or bigger off hand.
I noticed that one of the speakers had quit playing. THe gold pin had fell off the speaker terminated side on one set.  I also noticed that both the sets of speaker wires to both speakers had almost a 2 inch section where the clear plastic had  burned black on the negative or black side almost at the speaker terminal!!
Any ideas what could cause this?
Levi
« Reply #1 on: 13 Jun 2006, 07:39 pm »
Probably oxidation.  Do you have any good pictures?
rahank
wire burn
« Reply #2 on: 14 Jun 2006, 04:57 am »
Here is a link to the photo. Hope it works. It is late and I am trying a short cut.  I am wondering if the lose post at the terminated end of the wire caused a problem.  Ordered speaker cables from Bluejeans last night.  With 20 min to go before closing the guys ran to the post office and mailed my cables. Waiting for me when I got home.
http://photos.yahoo.com/rahank55
« Reply #3 on: 14 Jun 2006, 10:52 am »
I don't know what caused this, but I'd have amp and speakers checked.
eric the red
« Reply #4 on: 14 Jun 2006, 10:59 am »
Take the Packer fan's advice before you burn your house down-that does not look normal.
Kevin Haskins
« Reply #5 on: 14 Jun 2006, 03:19 pm »
Your amp is probably oscillating since it is both channels.   You don't want to continue running it that way.   A simple zobel network may solve the problem but I'd stop immediately and get in touch with Odyssey tech support.
laserman
  • Ambiguous-Optimist
Re: Monster cable burns!!
« Reply #6 on: 8 Jul 2006, 04:17 am »
Not to worry, the amp did not do this to the wires.  I have the exact same wires and use them in a system in my garage and in my three season room.  Both runs of wire experience this "burn" look.  After I cut the ends off and peeled back the covering, it was evident it was oxidation.  I contacted monster and they said it wouldn't degrade the sound but would warrant the wires if I returned them.  Since I am using them in the garage and in the three season room I thought I would just leave them in place.
Call monster and they will tell you what to do if you want to return them.
Later,
L
rahank
« Reply #7 on: 19 Jul 2006, 05:26 am »
Thanks to all who responded. I ordered cables from Bluejeans in Seattle.  Recieved them in the mail next day. Have no issue with heat. So must be the old cables. I will see if Monster responds!
