0 Members and 1 Guest are viewing this topic. Read 3948 times.
I don't why the second link works and the first link doesn't.
Norbert,> They are incredibly fast (frequency range up to 26.5GHz!) <I can't hear much past 20 KHz, and nobody else I know can either. So why does an audio cable need to work at 26.5 GHz?--Ethan
Hi Ethan Winer,Thanks for the post, it's an excellent question. To reproduce 20,000Hz with zero phase and time distortion, the implied frequency is around 2MGz. To reproduce 100,000Hz (SACD, DVD Audio) the implied frequency is somewhere around 10GHz! However this is all with just passing one tone. Music is a mixture of many different frequencies, the harmonics can reach into the GHz range even for normal audio CD's.If the cable is not capable of passing such high requencies, they begin to reflect. This reflection causes a cascading effect down the frequency range, ruining the correct phase and time in the audible range of 20Hz-20,000Hz. What differentiates live music and recorded music is the transient response and dynamic range. The human ear is very sensitive, that is why it's so easy to tell a recording from the live performance. To reproduce transients and dynamics in music with lifelike quality, the signal must have zero time and phase distortion. Nagys Audio cables will shock listeners in how lifelike the music will sound. ...
