0 Members and 1 Guest are viewing this topic. Read 4813 times.
Hey... we have a new SoftStart circuit. I know... Hypex already makes one. Why make another? The simple answer is that we needed something smaller that would fit in a new chassis design we have in the works. The second reason is that we didn't need all the functionality of the Hypex unit. The third and real reason is that our chassis vendor messed up on our dimensions and the Hypex unit wouldn't fit. :roll: The end result is the Exodus Softstart. It has a grand total of seven componemts. ...
Quote from: Kevin HaskinsPriced right at $35 populated. You only need to connect four wires to make it function...Now, we're talkin. That seems a whole lot more reasonable. Is the board populated, or is that part of the putting it all together?Ray
It is populated and all you have to do is connect the four wires for it to work.
Quote from: Kevin HaskinsIt is populated and all you have to do is connect the four wires for it to work.Cool! Say, that link about your supplies, it's not there, at least it wasn't as of Saturday. Also, as a suggestion, you might see if Hypex can also offer you a supply using the BHC Tnetwork caps. They are not available here in the States. They are a faster cap than the Pansonics, more on the order of the 4 pole Jensens. Not cheap, but will help to make those modules really sing. Ray
We ran into some problems while Q/Cing the 5-ch supplies. It looks like the build house who populated the PCB incorrectly used 47K resistors in five positions rather than 4.7K. Currently I'm going through the stock of boards to try and determine if all of them where done incorrectly. It only effects the DC protection scheme but I've pulled the 5-ch supply off the site until I get it ironed out.I'm a sceptic until proven otherwise on the T-Network caps. ;-)
Hypex builds those supplies, not me so you would need to talk to them.Also... figure the cost of a couple of those capacitors. Now figure that a minimum order is going to be 1000 units in order to do a production run. Start calculating the cost for building 100 boards with them. Calculate how much money we would have tied up in inventory and how many we would sell at the price necessary to cover our butts. My guess is it would take your years to sell them even if they have an audible benefit ...
I just don't have the money to take on another project at this date. I'm a small company and you have to focus on one goal at a time. ;-)
They don't produce it... they borrow it. Our kids will end up paying for our excessive spending habits.
