Cornet with digital amp and other questions?
0 Members and 1 Guest are viewing this topic. Read 1515 times.
kenscott30
« on: 9 Jun 2006, 11:16 pm »
Dear list.
Please excuse my questions, I am a little young and green.  I built a Charlize amp (15W) from DIY Paradise (i like it) and I run it off a CD player to some Omega Mini Me single driver speakers.  I like my CD player, Music Fidelity X-Ray V3 but I have always been curious about vinyl.  I am interested in building the cornet as my second DIY project.  I see a parts list and a PCB board.  I will need to get the tubes from somewhere, where?  And I will need a chassis.  Where can I get it?  The hagerman one is nice, I am assuming that that one isn't 85.00.  Would people recommend to just get the parts list or fancy it up a bit?  I have a metcal sp200 soldering iron.  Should I get a fine tip to do the soldering?  What tip do I need?  Any help with on the board soldering?  I know that I have a lot of questions...I would like to build this as I have heard that it is one of the best bang for the buck pre amps.
Ken
analog97
« Reply #1 on: 10 Jun 2006, 04:01 pm »
Ken,
I have built 3 Hagtech products including the Cornet2.  Like you, I had limited experience.  I had very few problems building the Cornet2, but I did find paying extra for the pre-drilled, ready-to-go Hagerman chassis irresistable due to my limited ability to do the metal work.  I used 2 soldering irons, both pretty cheap, one a 30-watt Radio Shack.  This was all I needed and it worked just fine.  I tried both .05" and .031" solder and both worked fine as well.  I am slow and steady and never had any faulty solder joints.  There is lots of room on the Hag circuit boards of the Cornet2 and Clarinet for using a moderate-size soldering tip, but I did find myself wishing for a  fine tip when I built the Bugle.  I think you will be fine, although I am not familiar with your solder iron.  I did the upgraded capacitors recommended by the engineer in his instructions.  To me, it would be silly not to do this i.e. not to take his seasoned advice.  Oh, yeah...tubes.  I got all mine from AES, again as recommended in the instructions.  Then I did upgrade tubes, for which there is lots of advice on this and other sites.   Good luck, but I don't think you can go wrong with this Hag stuff.
kenscott30
« Reply #2 on: 10 Jun 2006, 05:57 pm »
thank you very much for the well thought reply.  I bought my first records today at a used shop.  I meet a fellow shopper and I asked him how to tell a good record from a not so good on.  It was pretty fun digging around.  I then went to a local hi-fi shop and listened to a music hall mmf 5.  Nice TT.
I am lousy at metal work as well.  I will get the steps in motion for building this kit.  Could you give me a rough guess on your total investment CASH wise?
Thanks again!
Ken
analog97
« Reply #3 on: 10 Jun 2006, 08:25 pm »
Ken,
You can get an exact cost only by checking the parts cost at Digikey and AES. You also need to ask JH if he would sell you a ready-chassis.  He may have some extras. The total should be about $550 (including the Auricap upgrades).  Alternatively, you could just order the stock caps, save $50-60 and upgrade later.  Your call.
kenscott30
« Reply #4 on: 10 Jun 2006, 08:27 pm »
Sweet, thanks.
ken
