Industry Circles
Bryston Limited
Spade size for 4B-SST
0 Members and 1 Guest are viewing this topic. Read 1520 times.
james_dmi
30 May 2006, 05:07 pm »
Does anyone know the correct spade size for the 4B-SST?
I'm thinking of getting some Kimber 8TC using Kimber postmaster spades but don’t know which of the following options will be the best fit:
Kimber PM25 (1/4") :
http://www.russandrews.com/lookup/1/region/UK/currency/GBP/customer_id/PAA3051052506497QMRESTPNSXXMMBTS/product-KIMBER-PM25-SPADE-Kit-3910.htm
Kimber PM33 (5/16") :
http://www.russandrews.com/lookup/1/region/UK/currency/GBP/customer_id/PAA3051052506497QMRESTPNSXXMMBTS/product-KIMBER-PM33-SPADE-Kit-3912.htm
I also need to find out which size would be best for my B&W 802D’s if anyone happens to know that as well.
Cheers
Fife12
30 May 2006, 10:41 pm »
The Cardas GRS R9 are the best fit I have used.
They are 9mm and fit 5/16 posts! They fit like a glove.
If you want Kimber, I guess the PM33 should do.
Industry Circles
Bryston Limited
