-1db down at 20Hz.
0 Members and 1 Guest are viewing this topic. Read 2768 times.
Danny Richie
-1db down at 20Hz.
« on: 26 May 2006, 09:28 pm »
Dual 12" woofers and PR's with Apex Sr. amp and adjusted boost circuit.  :mrgreen:
RAW
-1db down at 20Hz.
« Reply #1 on: 26 May 2006, 09:39 pm »
Man that looks nice.
You did good Danny.
Jon L
-1db down at 20Hz.
« Reply #2 on: 26 May 2006, 09:49 pm »
That's the perfect size for:
putting Apogee Stage speakers on top to turn it into Apogee Mini-Grand type of system, or
putting a matching satelite speaker on top with subs standing long for the VonSchweikert/WattPuppy look.
BradJudy
-1db down at 20Hz.
« Reply #3 on: 26 May 2006, 10:09 pm »
And pretty to boot.  What are the dimensions on that bad boy?  I suspect the amp might be in the far sidewall, otherwise I think it would look sweet standing on end.
machine
-1db down at 20Hz.
« Reply #4 on: 27 May 2006, 12:07 am »
I'm guessing it is his standard design doubled up sharing a common center wall.  I'm fixing to put one of these together here pretty soon, and haven't decided if I like the passive radiators on the rear.  The depth of these won't allow much space to the rear wall in my setup, and I might try to put the radiators facing the side walls or make a tower with them all facing foreward.
Danny,
What are your thoughs on this?
Danny Richie
-1db down at 20Hz.
« Reply #5 on: 27 May 2006, 12:10 am »
So long as the air space is the same and it is well braced and solid then it will be fine.
