2 Identical Subs – 1 works, 1 doesn’t, please help
0 Members and 1 Guest are viewing this topic. Read 1159 times.
Pablo
Thanks for all the helpful information on my last post re: a ground loop issue.
I’ve got another problem that I just can’t figure out.  I have two identical subwoofers, one of which doesn’t work at all.  When I use the same power cable and AC outlet for the sub that’s working and connect to its twin, I keep blowing fuses.  Nothing else is connected.
Why does one work and not the other?  Short of taking it to a repair shop, does anyone have any ideas?  Thanks!
Soundbroker
    • http://www.thesoundbroker.com
« Reply #1 on: 9 Jun 2006, 04:52 am »
Time to have it repaired. When things blow fuses...something is amiss. Check with your MFG to see if it is a warranty issue or known issue.
« Reply #2 on: 9 Jun 2006, 09:05 am »
Something is shorting out in the sub.  Be careful!!  You can try the manufacturer or take it to a repair shop.
