Granite flexy
0 Members and 1 Guest are viewing this topic. Read 2373 times.
DTH
Granite flexy
« on: 30 May 2003, 03:39 am »
Hello,
Saw this ad on Audiogon:
http://cgi.audiogon.com/cgi-bin/auc.pl?accsrack&1054346372
and got to thinking again about building a flexy rack. Anyone have any idea on the cost of granite pieces like this guy is using? I imagine it can be had for cheaper than this product.
Also, anyone know of a good source for threaded rods? Home Depot maybe?
Juan R
Granite flexy
« Reply #1 on: 30 May 2003, 12:19 pm »
I had my system on marble and granite, change to maple wood and the difference in sound was notable in all aspect. If you going to build, my recomendation is wood. You can see my system in the gallery(page14). I got the rod from HD. they only sales the 36", you can add a copler and  another rod of 12" or 24". there are 3/4". I think if you go to a AC supply store you may get the 48" rods. :)
JoshK
Granite flexy
« Reply #2 on: 30 May 2003, 03:06 pm »
I am no materials expert but there has been quite some discussion in the teres mailing list about isolation platforms and materials used.  It seems that granite has a high pitched but audible resonance that can be noticed by rapping on the granite.  It apparently takes quite a bit of really heavy dampening (read lots of lead shot) to quiet this down.  I am afraid you are much better off using solid wood like maple or cherry or even MDF.  However the marble or granite looks great and that is what this vendor is appealing to.  You might look at some faux granite or marble that has better resonance properties (i.e. out of the audible spectrum) if you wish to go for this look.
There is a guy that makes his own racks that will sell his milled aluminum leggings that look FAR better than the bolts in flexies.  If I can dig up the link I will add it here.  They are a bit more expensive but much more solid and far better looking.  If you are going for granite for looks you owe it to yourself to go all the way.
DTH
Granite flexy
« Reply #3 on: 30 May 2003, 10:54 pm »
I did some more poking around re:granite and the consensus seems to be what has been posted here. So I guess I will go back to the wood. I would be interested in the legs you mention if it is easy to get to that info.
JoshK
Granite flexy
« Reply #4 on: 30 May 2003, 11:52 pm »
couldn't find the legs I was referring to but here is an attractive and cheaper alternative.  I think I will order up some of these to replace the legs in my Salamander rack.
go to e-store and click next to see legs
rosconey
Granite flexy
« Reply #5 on: 31 May 2003, 12:24 am »
you can still use granite or marble, just not by itself-glue with tile mastic to 3/4 mdf use a 1/4 x1/4 notch trowel and trim the sides with wood.
i did this the mastic grabs the vibrations before the granite or marble have a chance to ring.you can do the tap test to see the difference.
i've also used mastic inside speakers, works nice.
i did a top for my sub this way to add weight, liked it so much i did the sides of my diy speakers also.
if you want to do it , get 12x12 granite or marble at hd and get the pieces cut to size(split the center of shelf-4pcs per shelf at 4-10$ a piece),glue to the mdf and trim with maple or oak and grout (the solid 3/4x2 xlf stuff)use the same maple or oak for the 3 legs, use brass screws thru the sides of the legs into the shelf pieces.
has the mission furniture look.
wont cost 1/4-1/3 of what that one costs.
heck if you live in upstate ny let me know i do tile for a living and i'll make you one.
mgalusha
Granite flexy
« Reply #6 on: 31 May 2003, 12:59 am »
The Home Depot near us carries 3/4" all thread rod in 1ft, 3ft and 6ft lengths. Of course that doesn't mean all of them do.
Not sure if these are quite big enough for flexy shelves but would make a nice turntable base: maple cutting board
Mike
Brad V
Granite flexy
« Reply #7 on: 9 Jun 2003, 06:27 pm »
Hi,
I had real good luck with some Maple Veneered MDF from Home Depot. The boards are 97 inches x 16 inches. I used the 5/8" rods, as there isn't any reason to go to the bigger 3/4", unless the 3/4" rods appeal to you cosmetically.
Here's some pics of the finished product:
http://members.aol.com/bvirgil311/Rack2.jpg
http://members.aol.com/bvirgil311/Rack3.jpg
http://members.aol.com/bvirgil311/Rack4.jpg
http://members.aol.com/bvirgil311/Rack5.jpg
I can't believe that all of this was just $120.00.
Have a great day,
Brad
Malcolm Fear
Granite flexy
« Reply #8 on: 14 Jun 2003, 10:30 pm »
I've spent a lot of time with shelving. I have used sand boxes, MDF, Solid timber, granite and Corian (man made marble).
Corian is by far the best. You can buy "sink cutouts" from any kitchen shop that makes Corian kitchen benchtops. They will cut it to you spec cheaply. It is rigid, dense and does not ring.
