Bryston's PRO and regular consumer amps
0 Members and 1 Guest are viewing this topic. Read 1425 times.
PavelL
« on: 20 May 2006, 02:06 pm »
Bryston's PRO and regular consumer amps. WHAT's the difference? I was told that the pro version of 7B SST has some kind of a "volume pot at the back"/?!?!/ and that chassis is built stronger... TRUE? Any price difference there? :dunno:
jethro
« Reply #1 on: 30 May 2006, 09:28 pm »
I don't know about the SST amps, but the ST-PRO's have one,two or four adjustable gain pots on the front panel that you can change with a small screwdriver. They're almost invisible from a distance. I'm not sure about the build strength because all of my amps are the ST-PRO versions.
PavelL
« Reply #2 on: 1 Jun 2006, 11:06 pm »
Thanks, jethro!
