C'mon Darren, cat out of the bag here . What speakers are you building here if I might ask? Are you at the planning stage or well into it?jules
I'm considering the finish for a pair of high quality standmount speakers I'm building. Dark rosewood or walnut veneer would be great in our room but I can't find any suppliers for veneer sheets that are greater than 30cm wide, most are only approx 20cm wide.Does anyone know of any suppliers in Oz (preferably Victoria)?I guess I could run 2 sheets side by side, but I don't know how difficult it would be to get an invisible join. Any advice?Also, is there any difference in quality between the iro ...
Darren,I notice you're going to use a heap of stainless screws. I'm a great fan of stainless I have to admit and did use some ss bolts for the removable fronts of my cabintes. All the same, do you think you need them? After much thought I finished up making my boxes screwless because I simply can't see any gain to be had from using them. Particularly when you use 1" MDF the things stand up by themselves and the glued area is HUGE.jules
Rosewood is not for beginners, it can be very tricky to finish. Walnut would be much easier but I would recommend you stay away from highly figured pieces or burls as they can be tricky to apply/bend. IMHO you will be much better off, if you have never veneered before, using a single large piece rather than trying to edge join veneer. You might make a 3/4" bend if you wet the veneer with water as you make the bend. Forget making a bend with burl or highly figured veneer.-c
Also, is there any difference in quality between the iron-on veneer sheets and the normal sheets that you have to adhere yourself with contact adhesive?
Finally, what is the tightest corner radius on a speaker box that would not cause cracking of the veneer?
