HD Media Box: stand-alone music server?
0 Members and 2 Guests are viewing this topic. Read 3116 times.
Russtafarian
  • Typical reaction to the music I play
« on: 18 May 2006, 11:38 pm »
I just stumbled onto this device at www.digitalconnection.com . Has anyone tried it as a stand alone music server?
If I'm understanding what this does, you can (among other things) mount a hard drive loaded with music files in this thing and play them directly without the need for a computer or network. It says it supports AAC. I wonder if it will play ALAC files directly?
Cost is $360. "Audiophile" edition with "low jitter TCXO (temperature compensated crystal oscillator)" is $450.
Russ
ryno
« Reply #1 on: 19 May 2006, 12:48 am »
Doesn't look like there's a screen, how would you tell it what files to play if it is a stand alone?
Ryan
Russtafarian
« Reply #2 on: 19 May 2006, 03:22 am »
Yes, you would have to add a display device to navigate, which to is not a bad thing.  Instead of staring at a small display across the room, a compact video display could be set up near the listening position.
John Casler
Doublej
« Reply #4 on: 19 May 2006, 04:21 pm »
I don't understand the advantage of these devices over a computer these days.
For less than $500 you can buy a pretty beefy Dell machine with a flat panel monitor so why would I want this box?
Feisal K
    • DVD-A registry
« Reply #5 on: 19 May 2006, 05:03 pm »
Quote from: Doublej
Because you don't want the Dell sitting in your AV rack.
Actually, you'd want the Dell AND this box. the Dell can sit in another room - would host your music and video files, and this box sits in your AV rack and picks up AV from the Dell over the network.
Russtafarian
« Reply #6 on: 19 May 2006, 09:39 pm »
I really like my present music server, but I'd love to kick that big noisy tower with its tedious bootup cycle out of my listening room completely.  This compact box and a cheap HD loaded files (and yes a monitor or other display device) would be all I need for a fully functional music server.  The video and network capabilities are there if or when I want to use them.
I just want to know if anyone has used one and if it will play apple lossless files.
Feisal K
    • DVD-A registry
« Reply #7 on: 20 May 2006, 05:38 am »
there's a review linked on this board. you could ask the reviewer about Apple lossless
CSMR
« Reply #8 on: 21 May 2006, 07:28 pm »
Quote from: Russtafarian
Hard drives are noisy though, and there won't be space for an enclosure here.
michaelv
« Reply #9 on: 30 May 2006, 09:09 pm »
I think Squeezebox is much better choice. So you can use computer wherever it is and Squeezebox looks cool on top ov AV rack...
