VMPS 626R CDWG w/passive EQ crossover - 1 month report
0 Members and 1 Guest are viewing this topic. Read 4015 times.
John B
After a month of getting to know these speakers I'm ready to give a report.
Configuration: max everything, w/TRT caps, along with Xtreme Cables as internal hook up wire.
The most striking impression I've had of these speakers, in the configuration I have them, is the complete absence of their presence in the staging of the music.   Instruments and vocals come out of a 3-D bubble of space that is as wide and deep as I've heard from any speaker in my room, be it monitor or floor stander.   Instrument and vocal accuracy is as close to real life as I've obtained from electronics.  If ever there was a component that could challenge my upgraditis it be this one...unless big B comes up with some other bar raising invention.   :mrgreen:
yo2tup
« Reply #1 on: 18 May 2006, 08:42 pm »
sounds great!  i'm looking into picking up a pair for 626R's.  to replace my odyssey epiphonies.   got any pictures?
i didn't know the cdwg was available for the 626R's.   how much do they cost?  and whats acoustic equalization?  thanks  :D
Brian Cheney
    • http://www.vmpsaudio.com
CDWG
« Reply #2 on: 18 May 2006, 09:57 pm »
JohnB refers to the constant directivity passive EQ crossover.
Our constant directivity waveguide provides 180 degree dispersion (plus/minus 90 degrees) without lobing.  Off axis and on-axis response are the same.  Unfortunately CD dispersion spreads the same amount of mid and treble energy that once beamed at the listener (about 5kHz on up) over a very broad angle, and the result is HF rolloff.
The new passive EQ compensates for this, and restores flat response inspite of the 180 dispersion pattern.  This is remarkable, since boost cannot normally be achieved with passive means.  In pro sound, where CD horns have been in use for 30 years, electronics provide the boost (called CD or horn equalization).  With our passive CD EQ, no outboard electronics are required.
Brian Cheney
cdwg
« Reply #3 on: 18 May 2006, 10:02 pm »
I should add that the passive CD EQ crossover is used in conjunction with a technique called de-horning the tweeter, which causes its output to rise at about 6 dB/octave above 8 kHz or so.  The CD waveguide rolls this rise off at 6 dB/oct, resulting in flat trebles.
mikef
Re: cdwg
« Reply #4 on: 19 May 2006, 01:42 pm »
So, are these available yet, and what's the cost for upgrading my 626s? Are the CDWG and passive eq user installable?
Mike
Brian Cheney
CDWG
« Reply #5 on: 19 May 2006, 03:53 pm »
We're currently making CDWG's for new orders only, given the amount of sheer agony involved.  We don't have a CNC.  The CD EQ crossover will be user retrofittable (is that a word?) if you don't mind a little gluing and soldering.
John B
« Reply #6 on: 19 May 2006, 05:49 pm »
I fixed the Topic title :)  Thanks for the clarification Brian.  What this new passive EQ has added to the sonic presentation, from a listener point of view...is more clarity and definition to the high frequency information.  Cymbals for instance have cleaner "bell bronze sound signature" for lack of a better descriptive term.  The definition and tonal correctness of the impact of wood or brushes on bronze comes across with a more "real to life" tone to my ears.
I also still get a kick out of walking up to my speakers, coming from the listening position, and as the distance closes, still hearing a cohesive, fixed front sound stage; the feeling as I reach the meridian of the speakers, is that I'm now at the front of the stage looking up to the performers....it seems such a simple thing...but it's just so bleed'n COOL  :mrgreen:
Brian Cheney
bc
« Reply #7 on: 19 May 2006, 06:23 pm »
Constant directivity with frequency IMHO is now a prerequisite for
lifelike music reproduction from speakers.
Although 180 degrees dispersion is not the same as the polar response of live instruments and voices (and each instrument or singer has his/her/its own radiation pattern in space), 180 degrees is much closer to what occurs with musical instruments and voice in nature than that of the standard forward-firing speaker, even one with very high order filter slopes.  The live sources have a "wraparound" pattern that allows you to hear them well from behind and beside.  With  180 degree horizontal speaker radiation, you can get a good sense of sounds defined in space that is quite reminiscent of live music.
mikef
Re: CDWG
« Reply #8 on: 19 May 2006, 10:48 pm »
Brian,
BC said:
Quote from: Brian Cheney
So go ahead and get a CNC!
Let us know as soon as you have these available for in-field retro-fit. I bet you'll get a lot of orders from us 626 guys.
MIke
Se7en
Does anyone have pics of the 626R with CDWG???
« Reply #9 on: 20 May 2006, 07:19 pm »
I've seen some images of the RM30 and 40 with CDWG anf they look amazing!
-7
yo2tup
Re: CDWG
« Reply #10 on: 20 May 2006, 07:23 pm »
Quote from: mikef
Brian,
MIke
agreed!
 will the cdwg ever be available for existing 626r owners?
yo2tup
Re: CDWG
« Reply #11 on: 24 May 2006, 02:26 am »
Quote from: yo2tup
Quote from: mikef
Brian,
MIke
agreed!
Brian,
Can you answer this?
Brian Cheney
bc
« Reply #12 on: 24 May 2006, 02:30 am »
Could be 2 weeks, could be 4 months.  I am currently enjoying the unique ambivalance and misinformation supply available from domestic cabinet shops.  I won't stop trying until every 626 has a CDWG whether it wants one or not!!
J Harris
Re: VMPS 626R CDWG w/passive EQ crossover - 1 month report
« Reply #13 on: 15 Jul 2006, 10:18 pm »
Hi Brian, any news from the 626R WG people? We 626R owners are dying out here! 6 months of unbearable waiting after the huge build-up. The more I think about it the more I think the CDWG could be the final finishing touch my system needs - if not a total transformation.
Sorry to nag  :oops:
Patrick
edit: reading the posts above - if I order a brand-new pair of 626Rs (I'm considering some upgrades too because I stilll have spiral tweeters, no inside bracing, no lambswool, no elmers glue... though I do have the megawoofs) -- then do they come with the CDWGs??
Brian Cheney
« Reply #14 on: 16 Jul 2006, 12:15 am »
Yes, we are making CDWG's for new 626R's, no problem.  The smaller waveguides are a lot easier to make than those for the RM 40 which are on order from mls.
bushbison
« Reply #15 on: 16 Jul 2006, 04:44 am »
Hello Brian, et al; I was the "starter" of the post re: the dehorning and waveguides; a question that was not answered in my post: what's up with the "passive eq"???  :)  Like I stated in my post, I am VERY picky and do not want to give up (for some reason!!) on my RM30's, but am tiring of the constant 'tweaking"( w.g.'s on and off, eq-ing of the l-pads); if I don't get the results I crave (i.e. better mid dynamics with the waveguide + consistent neutrality), I may have to go back to Newform for the new(wer) r645v3's!!!
James Romeyn
« Reply #16 on: 18 Jul 2006, 06:48 pm »
IMO you should simply send your ribbon tweeters to Brian, pay him to modify them, install the latest xo's, & you will not have to tweek anything anymore.
Brian Cheney
« Reply #17 on: 18 Jul 2006, 09:42 pm »
We will have passive CD EQ xovers for in-the-field installation in a few weeks and I will send you the parts.  Just email me your shipping address.
Having the CD EQ xovers makes all the difference in the world.
