Dual part needed
0 Members and 1 Guest are viewing this topic. Read 2346 times.
dpump
Dual part needed
« on: 15 May 2006, 01:41 am »
Does anyone know where to get the Dual part#223-777? This is called the guide-white-that goes on the shaft underneath the tonearm and is the piece that transfers the horizontal motion of the changing mechanism to move the arm to and from the record in automatic mode. The guide looks like the black cap that touches the tonearm when the cueing is raised, but it is made from a clear or orange looking material that appears to be silicon.
   There is a company called dualparts which sells on Ebay. They normally sell this part, but they said that Dual in Germany is moving and they don't know if they will get any more parts from them. Thanks.
TheChairGuy
Dual part needed
« Reply #1 on: 15 May 2006, 03:07 am »
You might want to post on AudioAsylum 'Vinyl' section or VinylEngine.com as they may have more Dual afficianado's in those places than here.
We're trying mightily to make a vinyl statement at AudioCircle, but it's still a small (but rabid) bunch here   :wink:
Scott F.
Dual part needed
« Reply #2 on: 15 May 2006, 03:47 am »
