Question about I2S, Perpetual Tech P1, Versatility
0 Members and 1 Guest are viewing this topic. Read 2384 times.
kfr01
« on: 14 May 2006, 02:12 pm »
I'm finally looking to upgrade my M-Audio Sonica device to a better USB converter.
My issue:
I plan to try a variety of DACs and digital preamps, including the Tact audio room correction devices.  Thus, I'm wondering if a USB-I2S converter is wrong for me, versatility-wise.  It seems that I must stick with SPDIF somewhere in the chain to easily evaluate and use these devices.
However, I had an idea:  I buy an Empirical Audio Offramp I2S and get a P1 modded for better I2S input, then use the SPDIF output of the P1 to obtain the versatility I need while still taking advantage of USB->I2S conversion out of the computer.
Does this make sense, or am I better off ordering a regular Empirical Offramp?
Is the Perpetual Tech. P1 neutral enough and does it "play nice" with non perpetual technlogies DACs?
audioengr
Re: Question about I2S, Perpetual Tech P1, Versatility
« Reply #1 on: 15 May 2006, 06:15 pm »
Quote from: kfr01
My issue:
However, I had an idea:  I buy an Empirical Audio Offramp I2S and get a P1 modded for better I2S input, then use the SPDI ...
The I2S interface on the P-1A should work in theory, but I have one modded here and I'm having some trouble with it. This particular P-1A is a bit flakey anyway.  I will try to trace the problem...
If you do not plan to use the speaker correction of the P-1A, then I would not use it.
I think any advantage of the I2S will be eliminated if you add S/PDIF after the P-1A.  Better to go I2S direct to the DAC chip.
Steve N.
kfr01
« Reply #2 on: 16 May 2006, 12:35 pm »
Steve:
Thank you.  Any possibility of an I2S interface on a Tact device, then?
Karl
audioengr
« Reply #3 on: 16 May 2006, 04:57 pm »
Quote from: kfr01
Steve:
Karl
Actually, because of your question I figured-out what was wrong with the P-1A.  It was a matter of transmission-line termination.  After some rework to the P-1A, it is working great now with the Off-Ramp I2S.
I'm not familiar with TACT, so I can't answer the question.  If I knew the chips used, this might help.
Steve N.
audioengr
« Reply #4 on: 16 May 2006, 04:59 pm »
Quote from: audioengr
Quote from: kfr01
Steve:
Karl
I would recommend using the Off-Ramp Turbo S/PDIF converter if you want versatility.
Steve N.
