Music Hall MMF-9 turntable / Kavent A-210
0 Members and 1 Guest are viewing this topic. Read 1948 times.
Bill Baker
    • Musica Bella Audio
« on: 11 May 2006, 12:13 pm »
Excellent condition table that was used at Jam'n Audio as a Reference before he grabbed a JA Michell Gyro Dec.
 Light typical dust cover scuffing but otherwise perfect. Has less than 100 hours. Comes with everything including original double box packing.
 Asking $1050
 Also have a Kavent A-210 integrated hybrid that I am not sure if I want to sell or use to drive some of our Bella speakers.  Asking $550. Picture below.
Output Power.............................100W+100W (8Ω),
                                                    200W+200W (4Ω)
Class-A Output...........................10W+10W (8Ω)
Frequency Response.................5Hz - 40KHz (±1dB)
THD.................................... .........< 0.05%
Input Sensitivity.........................240 mV
S/N Ratio.................................. ..97dB
Input Impedance........................47k&#937;
Dimension (WHD)......................17" × 6" × 18"
Weight................................. .......45 lbs
        The preamp section uses a 12AX7 and a 6DJ8 tubes with low distortion by-passable tone control and loudness circuit. The power amplification uses four pairs of J-FET power transistors and is Class-A biased. The use of zero feed-back circuitry guarantees the most linear response at the lowest distortion. High-quality components include motorized ALPS volume control, SOLEN capacitors, 650VA toroidal transformer, 40,000uF capacitance, multi-function metallic remote control, and more...
Bill Baker
« Reply #1 on: 27 May 2006, 09:54 pm »
.Kavent SOLD
Bill Baker
« Reply #2 on: 29 May 2006, 11:35 pm »
Kavent A-210 SOLD
