Optical to SPDIF CABLE.. where to find??
0 Members and 1 Guest are viewing this topic. Read 1484 times.
matt99eo
« on: 10 May 2006, 07:58 pm »
Hey guys,
I am looking for an optical to SPDIF cable.  I have heard they exist but cannot find one... any ideas?
mp
dhollister
Re: Optical to SPDIF CABLE.. where to find??
« Reply #1 on: 10 May 2006, 08:59 pm »
Quote from: matt99eo
Hey guys,
mp
I don't know that such a cable exists to convert an optical to an electrical signal :)
I have a box called the Midiman CO2 that converts, though.  I think it cost me about $60.
orpheus
« Reply #2 on: 11 May 2006, 03:56 pm »
As already stated above, I don't think that there is a cable that does that kind of conversion.  I use a Monarchy Audio DIP for that purpose.  It also reclocks and boosts the digital signal, and offers AES/EBU input/output as well.  I think that there are some less expensive products that will convert toslink to SPDIF, but I don't know how well they work.
You would be better off using SPDIF from the beginning, and once you add in the cost of the converter, and a good toslink cable (required, a super cheap toslink cable sounds terrible), you might have been able to get something that offers spdif output on it's own, or at least be well on your way.
-Aaron.
matt99eo
RE
« Reply #3 on: 11 May 2006, 05:28 pm »
Yeah.  I agree with going straight out with an spdif.  The reason I am asking is that I cannot get my USB out on my gateway to interface with the Chime (signal coming out at wrong clock rate... see other post).  I have a different sound card that has an optical out which I can control the output clock rate.
Thanks for your input.
matt
