A question about the Cornet Mono Switch...
0 Members and 1 Guest are viewing this topic. Read 1204 times.
chriss
« on: 6 May 2006, 12:53 am »
Hi Jim,
We are about done with the Cornet II. I was wondering abouth the merits of the mono switch. I have read all the positives  about haveing a mono switch over at Vinyl Asylum but don't have more than a handful of mono records(so far).
My question is, do you find that adding the switch to signal path degrades the sound at all? If it doesn't make a noticable diffrence with the switch in the signal path then I'll go for it. But if you can hear a diffrence with it in place then I'll wait.
chris
hagtech
« Reply #1 on: 6 May 2006, 03:32 am »
The switch is basically out of the circuit until you go mono.  Then contacts collide and it becomes an issue.
jh
