Regulators
0 Members and 1 Guest are viewing this topic. Read 1672 times.
Felipe
Regulators
« on: 4 May 2006, 05:08 pm »
Hi all,
Any news on the new to be power supply regulators from Aspen ?
Hugh, do your plans to mass produce the so called super regulators went down the drain or just stalling ?
I'm eager to replace some PS on my CD player so i thought i ask !?
Filipe
AKSA
Regulators
« Reply #1 on: 4 May 2006, 11:04 pm »
Hi Felipe,
Production pcbs being manufactured right now, doing the instructions......
Board is large.  For 2 x +/-15V supplies, it's 114mm x 130mm.  There are four potted control modules on the pcb.
This will be fully built, ready to slot into a box.  This will add to cost, but is the only way I can keep the IP reasonably intact.
Beta tested now for the Orion crossover in two locations, works very well, I'm hoping this will be a good seller!
Hugh
Felipe
Regulators
« Reply #2 on: 5 May 2006, 11:29 am »
:o  :o   114 x 130 ... that is a big PS. How high ??
Is this same size if +5 V ?
Can they be converted to +12V ?
I am mainly interested in upgrading the CD player , so i will be needing +5V and +/- 12V.
But that seems rather large to fit inside a CD player   :(
AKSA
Regulators
« Reply #3 on: 5 May 2006, 12:20 pm »
Felipe,
A single 5V supply will be about a quarter that size.
+/-12V and +5V would be 3/4 that size, and would need to be tailored to the current draw.
Size would still be large.  Height is around 40mm, including series pass heatsinks and filter caps.  I agree, it is too large to put into most CD players, this is not actually a possibility I'd considered.  But it's still fairly tight on the layout;  the modules are 36mm x 25mm, and there is one module per supply, so four for 2 x +/-15V.
Thank you for your interest!!
Hugh
PSP
transformers for new power supply?
« Reply #4 on: 5 May 2006, 02:52 pm »
Hi Hugh,
Exposing my vast ignorance about transformers, what kind of transformer do you recommend for your power supply?
What do we need?  15VAC and 0? or 15-0-15?  Or, do we want 18VAC, which is then regulated down to 15?
What about noise?  Do we want a torroid, split-bobbin, or what?  Since I don't have a clue about transformer design or how to think about the trade-offs involved in selecting a transformer, please be very basic.
As I consider the layout for the Orion ASP (mine will follow PT914=Philip's lead and use two ASP boards per channel to take advantage of the GK-1's sub out), I don't want a noisy transformer in the ASP box.  I can put the new PS in it's own enclosure, but then I have long leads => more opportunity for RFI, etc. and more inductance.  Maybe I just worry too much...  :?
Thoughts?
Peter
AKSA
Regulators
« Reply #5 on: 6 May 2006, 05:24 am »
Peter,
15-0-15Vac should be fine;  best is toroid or split bobbin.
These have low external fields. Regulation is not so important, actually, and for 200mA per rail you should specify at least 300mA rating.
Hugh
