0 Members and 1 Guest are viewing this topic. Read 6329 times.
I'd recommend checking the new x-ls line from AV123 ($199 for a pair of bookshelves and $199 for the X-Sub). You can read a review of it from the May issue of Affordable Audio.http://www.affordableaudio.org/http://www.av123.com/products_product.php?section=speakers&product=82.1Having owned both Aperion and AV123 speakers, I would highly recommend that you look into the x-ls line or even consider the rockets if you're willing to spend a bit more. You can also pursue the question at the AV1 ...
Okay, we're looking at:Aperion 532Axiom M3 v2AV123 xLS (or for another $100, the Onix Ref 0.5 Monitors)Ascend CBM 170-SE
Quote from: bodhidogOkay, we're looking at:Aperion 532Axiom M3 v2AV123 xLS (or for another $100, the Onix Ref 0.5 Monitors)Ascend CBM 170-SEThe Ascend's are the best sounding of that group.
If the x-ls had a different crossover I think it could be more competitive with the Ascend.
A BIG thankyou for telling me about the Onix speakers, as I never would have found them on my own.
Actually, there is a new crossover kit out for that speaker that promises to be very good.Keep your eye on TONE-Audio Online (www.tonepublications.com)We are getting the crossover upgrades any day, so we should havea review in about 60 days.Sounds like this takes a great pair of budget speakers to a whole newlevel! We'll keep you posted!
There is a new crossover kit for the Onix x-ls speakerscoming our way.
