How many hours, whoa to go?
0 Members and 1 Guest are viewing this topic. Read 2692 times.
rick57
« on: 2 May 2006, 08:48 am »
.  .   would it take an innocent newbie to make an Aksa:
select & buy the extra bits, assemble say a kit case, fit everything, check and test – 15/  25/  35/ 40? hours :?:
Cheers
EchiDna
« Reply #1 on: 2 May 2006, 11:21 am »
I'd say less than 25 hours...
but then again, you could spend 25 hours building a case alone :)
or in my case (pun intended!) two+ years to complete my final box!
AKSA
« Reply #2 on: 2 May 2006, 11:31 am »
Rick,
Glen is about right;  25 hours all up.
However, since you live in Melbourne, you get to bring it to me if there are difficulties.....  that could bring the time down a little........
Hugh
fajimr
« Reply #3 on: 2 May 2006, 02:13 pm »
hi rick
here's my take on this... I came into this a total DIY newbie, meaning that I had never picked up a soldering iron before taking on the AKSA 55 N+ (do a search on my name in this circle and you can follow all my inquiries)... I started with a couple of practice kits to get a feel for soldering (keep that tip clean!!!  that's the most important thing I learned... and yes, someone told me that along the way but I had to learn it on my own) and then jumped into the amp...
you ask how long.... hmmm,  it's hard to say in actual work time but I would say that 25-30 hours is a good number.  For me, with all sorts of life things going on that time has taken me about 2 months  :lol:  but that's o.k. as I've learned a ton in the process.  Being a newbie I am very methodical in the process, double and triple checking everything.
and the best thing is that if you have a problem/question/issue there always seems to be someone around to jump in and help.  for me that has been reassuring.  now if I had lived as close to hugh as you do, he might have had to change his locks.   :o
FWIW- my amp is assembled and waiting to be tested (again I am looking for time to do that)...
good luck on the journey..
ask more questions
gorgeousgeorge
« Reply #4 on: 3 May 2006, 03:17 am »
im the same as Jim, absolutely no experience in DIY electronics, and I had no problem. If your interested in great quality audio for small $$$ i say go for it!!
its a load of fun and immensely satisfying once complete.
Cheers George
rick57
« Reply #5 on: 3 May 2006, 03:25 am »
Thanks guys, that's pretty damned reasonable    :wink:
ginger
Rick57 - Unsolicited Recommendation
« Reply #6 on: 15 May 2006, 04:55 am »
Rick57,
I recognize the name from some other forums (on which I post as Gingertube as someone else had already registered as Ginger).
I have been a bit delinquent on this forum since completing my GK-1 and 55N+ and subsequent mods BUT have been posting heaps on those other "toob" forums while trying with mixed success to design and build a "Toob" amp to better the 55N+. A large part of this delinquency is the fact that The GK1 and the 55N+ have long since been finessed to the Nth degree (at least I haven't been able to come up with additional worthwhile tweeks) and can be considered a mature product.
You can guage the success of my tube amp endeavours by the fact that the 55N+ is STILL my reference amp against which I judge the performance of these new amps - the simplest of which costs at least 2X a 55N+ and the more sophisticated of which cost about 10X a 55N+.
The 55N+ is the most tube like SS Amp I've ever heard and for DIY newbies it has some real advantages:
1) Sound which is better than 95% of tube amps (whilst offering tube character)
2) Voltages of <50V compared to tube amps with voltages of >250V (Save charcoaling more Audio DIY'ers that way). I can happily say to even complete newbies "have a go" at a 55N+, where I hesitate to suggest to some, that they dive in to the latest tube design, with my fingers crossed in the hope that they survive the experience.
3) A comprehensive "How to" manual.
Knowing that you are a bit of a "Toob" Nutter (no offense intended, being a toob nutter myself) I can happily and confidently RECOMMEND to you the AKSA 55N+.
I can also tell you that no matter which power amp I'm using at any time (AKSA 55N+, EL84 "Baby Huey" Ultralinear Push Pull, PPP EL34 Triode Mode, 845 SET etc.) they are all driven from my GK-1 which has a tube buffer output stage which includes some clever, but simple (and therefore elegant) tricks.
Ian
Geoff-AU
Re: Rick57 - Unsolicited Recommendation
« Reply #7 on: 15 May 2006, 08:19 am »
Quote from: ginger
There's still 240V mains wiring, but the typical SS amp has clear high and low voltage sections.  It's not safe from idiots but less prone to costly mistakes than a tube setup.
AKSA
« Reply #8 on: 15 May 2006, 12:23 pm »
AND, Rick,
Since you live in Melbourne, if you buy/build, you get to bring it to me to throw the Frankenstein switch!!
Hugh
EchiDna
« Reply #9 on: 15 May 2006, 12:27 pm »
geez Hugh... despite my own misgivings at the time, there is no way I would let some one else do the initial power on test!  :D
AKSA
« Reply #10 on: 15 May 2006, 12:45 pm »
Ah, yes,
But quite a few don't agree, Glen, and remember, I gotta VARIAC!!
Chars,
Hugh
EchiDna
« Reply #11 on: 15 May 2006, 02:30 pm »
Call it blind optimism, but after building it - I'd want to be the bloke who fried it... but then again, with your quality instructions Hugh... letting the smoke escape was not a possibility!
(don't let it go to your head now!)
 :roll:
AKSA
« Reply #12 on: 15 May 2006, 10:42 pm »
Glen,
No chance of that - my head is now so crammed full of circuits I'm getting headaches.......  quite a few of them I can't work out, have to sleep on them, hope I understand in the mornings!
Hugh
